Image controls in modern dialogs
I am trying to write a visual editor for rooflight placement. I was hoping to toggle the image associated with an image control (ie rooflight or standard sheet) but the clicking of an image control does not fire an event. The images are 50x75 pixels.
NNA, is this by design or a bug and is it likely to be fixed? Alternatively am I doing something wrong. My test code is below.
Thanks
Bill Wood
PC VW 11.01
PROCEDURE ImageTest;
VAR
gDlogID,gDlogResult : INTEGER;
gOKdlog,rsAvailable : BOOLEAN;
FUNCTION Define_Dialog: INTEGER;
VAR dialogID,i : INTEGER;
BEGIN
dialogID := CreateLayout('Rooflight Editor',True,'OK','Cancel');
CreateStaticText(dialogID,4,'Set Rooflight:',-1);
CreateControl(dialogID,5,1,'',1010);
CreateControl(dialogID,6,1,'',1010);
CreateControl(dialogID,7,1,'',1010);
CreateControl(dialogID,8,1,'',1010);
CreateControl(dialogID,9,1,'',1011);
CreateControl(dialogID,10,1,'',1010);
CreateControl(dialogID,11,1,'',1010);
CreateControl(dialogID,12,1,'',1010);
CreateControl(dialogID,13,1,'',1010);
SetFirstLayoutItem(dialogID,4);
SetBelowItem(dialogID,4,5,0,0);
SetRightItem(dialogID,5,6,-2,0);
SetRightItem(dialogID,6,7,-2,0);
SetBelowItem(dialogID,5,8,0,-2);
SetRightItem(dialogID,8,9,-2,0);
SetRightItem(dialogID,9,10,-2,0);
SetBelowItem(dialogID,8,11,0,-2);
SetRightItem(dialogID,11,12,-2,0);
SetRightItem(dialogID,12,13,-2,0);
Define_Dialog := dialogID;
END;
PROCEDURE Drive_Dialog(VAR item:LONGINT; data:LONGINT);
VAR temp_i,i:INTEGER; temp_s:STRING; result:BOOLEAN;
BEGIN
CASE item OF
5,6,7,8,9,10,11,12,13: alrtdialog('image hit');
END;{of CASE}
END;
BEGIN {MAIN}
rsAvailable:= SetVSResourceFile('C:\Program Files\VectorWorks 11\images');
gDlogID := Define_Dialog;
gOKdlog := VerifyLayout(gDlogID);
IF gOKdlog THEN gDlogResult := RunLayoutDialog(gDlogID,Drive_Dialog);
END;
Run(ImageTest);
Rick,
rsAvailable is a BOOLEAN signifying if the resource file was successfully loaded.
I have now changed my tack and use checkboxes to swap the content of image controls. However, it still would be nice to have an event on clicking an image control.
PS the code framework was hacked from an NNA example.
