luiso Posted June 28, 2005 Share Posted June 28, 2005 Good morning: In the VW_Help (Dialogs) we have two basic dialog levels (BASIC DIALOG & BASIC DIALOG+CONTROLS)but both procedures display the same dialog (without controls). This are the procedures. Where is/are the errors? Thank you. {BASIC DIALOG} procedure CreateDialog_BD; VAR id: LONGINT; result : LONGINT; BEGIN id := CreateLayout('Revise Layer Link', TRUE, 'Update', 'Cancel'); result := RunLayoutDialog(id,NIL); END; RUN(CreateDialog_BD); {BASIC DIALOG + CONTROLS} procedure CreateDialog_BDC; VAR id: LONGINT; result : LONGINT; BEGIN id := CreateLayout('Revise Layer Link',TRUE,'Update', 'Cancel'); CreateStaticText(id,4,'Relink to:',-1); CreatePulldownMenu(id,5,32); CreateGroupBox(id,6,'Link Options',TRUE); CreateCheckBox(id,7,'Link object is locked'); CreateCheckBox(id,8,'Name Link:'); CreateEditText(id,9,'Untitled Link',26); result := RunLayoutDialog(id,NIL); END; RUN(CreateDialog_BDC); Quote Link to comment
Rick Francken Posted June 28, 2005 Share Posted June 28, 2005 Luiso, you have to implement a callback procedure for driving the dialog. Then, when you call RunLayoutDialog, pass the callback procedure for the second argument. Your callback has to have the following syntax... PROCEDURE Drive_MyDialog(VAR item:LONGINT; data:LONGINT); begin {code goes here} end; Then, instead of calling RunLayoutDialog like this: result := RunLayoutDialog(id,NIL); call it like this: result := RunLayoutDialog(id,Drive_MyDialog); You should find the information under "Vectorscript Guide...User Interface...Creating a Custom Dialog...Handling Events" in the VW Help. The procedure shown on that page is how the dialog callback procedure is implemented. In the "SetupDialogC" case, you would set the initial state and value of each control. Using your example above, the skeleton of your case statement might look like this: case item of SetupDialogC: Begin {set up your controls here} End; { user selected OK button } 1: BEGIN {...} END; { user selected Cancel button } 2: BEGIN {...} END; {user selected pulldown menu} 5: begin {...} end; {user selected "Link object is locked" checkbox} 7: begin {...} end; {user selected "Name Link" checkbox} 8: begin {...} end; End; {case} Good luck, -Rick Francken Quote Link to comment
luiso Posted June 29, 2005 Author Share Posted June 29, 2005 Thank you very much Rick: If I can advance - thanks for your instructions- I will say you it to you know. You have been very amiable and very didactic. Quote Link to comment
Rick Francken Posted June 29, 2005 Share Posted June 29, 2005 You are welcome. Glad I was able to help. Quote Link to comment
luiso Posted June 30, 2005 Author Share Posted June 30, 2005 Thank you Rick: Good luck. Quote Link to comment
