BalinB Posted January 14, 2004 Share Posted January 14, 2004 I downloaded this from VectorDepot along with other files with extensions VST, VSO, VSM. I've read the manual, trial and erred, and admit I can't figure it out. How do I make these things work? Elementary. I have the file xxxxx.vst. Now what? Is this stuff Vectorscript? Baffled, Balin Quote Link to comment
Guest Posted January 14, 2004 Share Posted January 14, 2004 The naming convention is: .vst VectorScript Plug-in Tool .vso VectorScript Plug-in Object .vsm VectorScript Plug-in Menu Command Copy those files into your "Plug-ins" folder. Run VectorWorks. Choose the menu command "File / Workspaces... / Workspace Editor". Now add the new menus and tools to your workspace by dragging the menu or tool name from the column on the left over to the appropriate menu or tool palette on the right column. If you don't know what category they are under (on the left) you can open the first item labelled "All Menus" or "All Tools" and find it alphabetically. Hit OK and then you can use your new menu and tool plug-ins. Quote Link to comment
