Developer Wiki and Function Reference Links Read more... ×
benis
Select all instances of currently selected symbol
Could anyone tell me if they have a script or could write a script that would do the following:
I select an instance of a symbol in a drawing then run a script that will select all other instances of that selected symbol. I want to use this in order to edit the records of all the instances of a particular symbol in the drawing simultaneously without having to constantly keep going through the custom selection routine or going throught the drawing and individually selecting instances of the particular symbol. I want to be able to select a single instance of a symbol then in one step select all of the remaining instances. It would also be nice if the script could work for plug-in objects, or another script could be written for plug-in objects.
I would greatly appreciate the help. I am using VWA 9.5.3 on a Mac (OS 10.2)
Ben [Roll Eyes]
procedure selectLikeSyms;
var
theSym : HANDLE;
symName : STRING;
selCriteria : STRING;
begin
theSym := FSActLayer;
if (GetType(theSym) = 15) then
begin
symName := GetSymName(theSym);
selCriteria := CONCAT('S=', symName);
message(selCriteria);
SelectObj(selCriteria);
end;
end;
run(selectLikeSyms);
If the symbol name is multiple words with a space character, then the script I posted will need to be tweaked to put quote marks around the symbol name.
Replace:
with:
selCriteria := CONCAT('S=''', symName, '''');
Two adjacent quotes will act like an escape and put one quote character in the string. Therefore you need three single quotes after the S= and you need four single quotes before the close paren.
