Paolo
Databases on the fly
Is there a way to create via VectorScript a database on the fly (if it is not already in the document) or, as a second chance, import it from a template document.
The first solution is available with WorkSheets (CreateWS), the second is available for Symbols (CopySymbol). I've not found nothing similar for Databases.
Can someone help me? Thanks!
[Confused]
You can create a database row within a VectorWorks worksheet by using the SetWSCellFormula vectorscript function. Pass 0 as the column argument to set the database formula for a row. See example below:
procedure createdb;
var
theWS : HANDLE;
formula : STRING;
begin
theWS := CreateWS('my WS', 1, 1);
formula := '=DATABASE((T=RECT))';
SetWSCellFormula(theWS, 1, 0, 1, 0, formula);
formula := '=T';
SetWSCellFormula(theWS, 1, 1, 1, 1, formula);
end;
run(createdb);
