Paolo
Classes in PIO's
Is it possible to dinamically change a custom object menu displaying all available classes in the document?
The goal is to have specific plugin elements with classes choosen from the standard document list (not style-1, style-2, style-n prepared in the usual way in plugin parameters editor).I've tried to set the list in the menu at object creation (IsNewCustomObject), but when I attempt to change menu parameter values with SetRField (in a FOR cycle passing a class string at each loop), the result is the insertion of only the last value passed, not the entire list.
I fear this is not possible as I have never seen, till now, a plugin with such behaviour, but I'll be glad to be contradicted. smile.gif" border="0
Paolo,
If I understand you correctly. You can changethe classes attached to different object withina PIO. I don't quite understand how your trying to do it. Sorry I can't be more helpful.
Dave
That is a very good question indeed!
If I uderstand it correctly:
Is it possible to change the value-list of a PIO pop-up parameter from inside it?
Note: To chage a parameter's value is easy, what Paolo wants is to change the options that will appear on the pop-up at the Obj. Info Palette...
rgds,Alexandre
rgds,Alexandre
-Yes, it is so, let's have, for example, a parametric chair in which legs material have a pop-up menu class where we may choice from one of the classes available on the drawing.
ciao,Paolo
