ArenaLights Posted February 13, 2002 Share Posted February 13, 2002 Is there, or could there be a way to find by the rotation of the unit? For example I would like to find all units that are rotated 90 degrees so that I can assign an appropriate label legend. It would be very nice to be able to ask the find and modify function to look for a specific rotation and then modify all units with that rotation. Thank You Tlaloc Lopez-Watermann Lighting Fellow Arena Stage Quote Link to comment
kmoore1 Posted February 13, 2002 Share Posted February 13, 2002 quote: Originally posted by ArenaLights: Is there, or could there be a way to find by the rotation of the unit? For example I would like to find all units that are rotated 90 degrees so that I can assign an appropriate label legend. It would be very nice to be able to ask the find and modify function to look for a specific rotation and then modify all units with that rotation. There is no way to do this through the Find and Modify command or through the custom selection dialog. It is a good idea though and I'll have to add it to the ever expanding wishlist. It would be a pretty easy VectorScript project to make a selection set from all lighting instruments with the same rotation. HTH Quote Link to comment
