Particular Posted March 27 Share Posted March 27 I have a some data-visualizations I typically apply in viewports to differentiate things like which parts of the plan will be demolished. When I reference the plan to another file, and apply the identical visualization it does not work. It in fact does not identify the drawing items in the referenced plan. I'm not sure if this is a bug, or if I am failing to tick a box somewhere. Any ideas? Thanks! These are the criteria applied to the viewport in the base file, and the result in the sheet layer viewport. These are the criteria applied to the viewport with a referenced plan in another file. There are no objects that meet the criteria, and no visualization is applied. 1 Quote Link to comment
Particular Posted April 4 Author Share Posted April 4 I managed to solve my own query. The reason the visualizations aren't applying is that the referenced classes are not 'in' the file. The trick is to adjust the Viewport Class Properties, and toggle it to "Use viewport-specific class definition". Now the Classes are filtered by the data-visualization, and everything works. change this: to this: 2 Quote Link to comment
