This is a small list of things that improve the quality and speed of the work.
-Different kind of arrow head in the same line.
-When you draw a open polygon make available put arrow heads, (of course when you draw a close polygon this feature is not available).
-The offset tool have to keep a polyline when the original object is a polyline (eg. make a polyline with lines and arcs then select all and compose this selection, when you have finished use the offset tool in any mode (by distance mode or point mode and you will see that second object (the copy) is a polygon...and try to edit this copy it is practically impossible and/or annoying.
-Adjust the size of the Workspace Editor window.
-When you use a "Line Thickness" in a line or anything it would be fantastic to be able to choose by where the thickness of the line grows by outside, on the inside or by the center.
JC
Hi everyone.
Thanks to all.
2 answers to this question
