Jason Byron Teague Posted January 14, 2002 Share Posted January 14, 2002 I have built a new plot, creating positions then adding all my fixtures. I just realized that the symbols, although filled, will not cover over a light position object. The symbols cover normal lines and polygons just fine, but there's an annoying line (the batten) right throught the center of all my fixtures. How do I fix this? Thanks Jason Teague Quote Link to comment
kmoore1 Posted January 14, 2002 Share Posted January 14, 2002 quote: Originally posted by Jason Byron Teague: I have built a new plot, creating positions then adding all my fixtures. I just realized that the symbols, although filled, will not cover over a light position object. The symbols cover normal lines and polygons just fine, but there's an annoying line (the batten) right throught the center of all my fixtures. How do I fix this?Thanks Jason Teague If the lighting positions are on a different layer from your lighting instruments then you'll need to make sure the lighting position layer is below the lighting instrument layer in the layer stacking order. If they're on the same layer then select your lighting position and choose the "Send To Back" command from the "send" group on the tool menu.(shortcut is either cmd B (mac) or ctrl B(win)) HTH Quote Link to comment
