9.5.0 patch problems
quote:
Originally posted by daisymurray:
since installing 9.5.0 patch from the downloads page on a mac running OS 9.1 and spotlight v9.5, I'm unable to update instrument info on an existing plot. suspect the 'lighting device vso' is the problem but have overwritten the previous version.
I haven't heard other reports of people having problems. You might try re-downloading the patch to make sure you have a good copy of the file. It should come down as binhexed stuffit archive and should expand as Archive.sit. The lighting device plug-in should have a time stamp of Dec 20, 2001 10:02am and should be about 60k
If this doesn't work, e-mail me and I'll be glad to send you a copy of the original lighting instrument.
kmoore@nemetschek.net
thanks kevinhave done as suggested but am still getting following errors:Line #29: _275 :=CONCAT(KDRAWBEAMERR,((RAD2DEG(_268)-90)+(RAD2DEG(_261))),KDEGSTR);BEGINTEXT;_275 ENDTEXT;SETTEXTVERTICALALIGN(LNEWOBJ,3);POPATTRS;_266 :=0;END ELSE BEGIN _266 :=_264 /COS(_268);END;_186[1]:=
| { Error: Identifier not declared. }
| { Error: Expected a string. }
| { Error: Expected ) }
| { Error: Did not expect this after end of statement - missing ;? }
also moving instruments causes them to disappear!
is the previous v9.5 of the 'lighting device vso' available as a download without having to download the complete install with which i had problems. will this provide a solution?
has anyone else experienced difficulties?
