kmoore1 Posted December 30, 2001 Share Posted December 30, 2001 quote: Originally posted by daisymurray: since installing 9.5.0 patch from the downloads page on a mac running OS 9.1 and spotlight v9.5, I'm unable to update instrument info on an existing plot. suspect the 'lighting device vso' is the problem but have overwritten the previous version. I haven't heard other reports of people having problems. You might try re-downloading the patch to make sure you have a good copy of the file. It should come down as binhexed stuffit archive and should expand as Archive.sit. The lighting device plug-in should have a time stamp of Dec 20, 2001 10:02am and should be about 60k If this doesn't work, e-mail me and I'll be glad to send you a copy of the original lighting instrument. kmoore@nemetschek.net Quote Link to comment
daisymurray Posted December 30, 2001 Author Share Posted December 30, 2001 thanks kevinhave done as suggested but am still getting following errors:Line #29: _275 :=CONCAT(KDRAWBEAMERR,((RAD2DEG(_268)-90)+(RAD2DEG(_261))),KDEGSTR);BEGINTEXT;_275 ENDTEXT;SETTEXTVERTICALALIGN(LNEWOBJ,3);POPATTRS;_266 :=0;END ELSE BEGIN _266 :=_264 /COS(_268);END;_186[1]:= | { Error: Identifier not declared. } | { Error: Expected a string. } | { Error: Expected ) } | { Error: Did not expect this after end of statement - missing ;? } Quote Link to comment
daisymurray Posted December 31, 2001 Author Share Posted December 31, 2001 since installing 9.5.0 patch from the downloads page on a mac running OS 9.1 and spotlight v9.5, I'm unable to update instrument info on an existing plot. suspect the 'lighting device vso' is the problem but have overwritten the previous version. also moving instruments causes them to disappear! is the previous v9.5 of the 'lighting device vso' available as a download without having to download the complete install with which i had problems. will this provide a solution? has anyone else experienced difficulties? Quote Link to comment
daisymurray Posted January 4, 2002 Author Share Posted January 4, 2002 have been unable to solve problem and would appreciate an emailed copy of the previous lighting device please thanks in advance Quote Link to comment
