Symbol rotation
ccastle
It is probably easier for you to just test the values before you draw the first rectangle so you draw it the way you want rather than draw with the default values and then try to rotate.
I think you are just going to have to calculate the points you want the symbols at and then place them. Since the output of the Marionette object is effectively a group the symbols should move with the object.  Insert Symbol node is in the BIM:Symbols folder.
