Antonio Landsberger Posted September 20, 2023 Share Posted September 20, 2023 Let's say we have (styled) walls with symbols, (styled) doors and (styled) windows. A script could go through all walls, but then what? There is GetNumOfWallBreaks, but this will only give me an integer. There is GetObjExtentsInWall, but this requires the SymbolH additionaly to the WallH. Also I would probably get FALSE for round walls as the boolean, not just for all the checks with all the different symbols etc. Isn't there an easier and cleaner way of doing that? The goal is to have a worksheet reporting primarily on windows and show in which wall style the window is placed in one of the columns. That can only happen, if the windows have this information (in a record format for example). A script could be a way to read out and write this information into the record format attached to the windows. Quote Link to comment
Maarten DE Posted September 21, 2023 Share Posted September 21, 2023 In the past FIn3D( wallHandle ) worked to get the first inserted object in the wall. NextObj will get you the next etc. I just did a quick search and here's an example that you might change for your needs: 1 Quote Link to comment
Antonio Landsberger Posted September 21, 2023 Author Share Posted September 21, 2023 That sounds just like what is needed. Thank you! Quote Link to comment
