MarCur Posted June 29, 2023 Share Posted June 29, 2023 Is there any option I'm missing to actively have the mouse cursor sync across multiple panel views for 2D entities and planar operations?? Let's say I've jut a top/plan and an iso view and I'm tracing a survey (hotspots) I'm not able to see neither the cross hair cursor sync across the views (to check actual position in both views) nor if I start using the polygon or polyline tool in a view and then switch to another the tool does not draw enything. It seems just to let me select and highlight objects move them in a view (but without realtime update of the position in the other views) that updates only when the movement ends. It seems that the multiple view panel operability is restricted to 3d tools only, is that so? Quote Link to comment
