Dimmer numbers
td4stage
quote:
Originally posted by td4stage:
I have *sucessfully* been importing data back and forth between SL and Lightwright. I have just added dimmer info to LW and when I imported the data into SL, any units which are ganged (two-fered) do not recieve a dimmer number. All single units get their dimmer numbers as assingned!
What am I missing?
Pat
I wasn't able to duplicate this problem. The instrument labels may not be updated when you import, so select the instrument and check to see if the value in the object info palette is correct. It may just be that the two-fer label is out of sync with its instruments. If so just select your two-fers and press the "update Insts" check box in the object info palette. This will make the two-fer go look up all its info from the instruments and should correct the problem.
Kevin Moore
Product Manager
VectorWorks SpotLight
What am I missing?
Pat
