xlp3336 Posted June 15, 2023 Share Posted June 15, 2023 for example, there are multiple identical buildings on the site, after renfence imports, unlocks and arranges, I now modify the original file and run the update, only one remains and restores it to its original position. thanks! Quote Link to comment
EdwardMatthew Posted June 16, 2023 Share Posted June 16, 2023 20 hours ago, xlp3336 said: for example, there are multiple identical buildings on the site, after renfence imports, unlocks and arranges, I now modify the original file and run the update, only one remains and restores it to its original position. thanks! When you reference an external Vectorworks file, changes made to the original file should be reflected in the referencing file after updating the reference. However, if you have moved, copied, or duplicated the referenced items within the referencing file, and then updated the reference, this could potentially cause issues. Always keep a backup of your files before making significant changes to your references or your project in general to prevent loss of work. This is especially important when working with complex files with multiple references. 1 Quote Link to comment
