nicolo
text in Vectorscript
the command textsize (3mm) is accepted by the compiler but it interprete the value as point.
Is it possible to set the unit in metric?
Thanks
1 answer to this question
I don't think you can specify units for the TextSize() routine, but since you're doing this in VectorScript you could certainly just do the conversion from millimeters to points in your script. 1 millimeter is approximately 4.22 points.
