nicolo
    5
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    electrical engineer
  • Location
    camogli/italy
  1. I would like that the program should remember the last setting of the align option ,in order to perform multiple alignement without having to set it each time (it seem tome that the left setting is always present). I put and underscore on non important format They appear in the bottom in the resource palette but in the top in the info palette IS it a bug? I am using the windows version. Many thanks
  2. I would like that this routine will be operational again and I don't know why a so useful procedure (replace by nothing) has been set to obsolete. In many cases it is indispensable. Many thanks
  3. the command textsize (3mm) is accepted by the compiler but it interprete the value as point. Is it possible to set the unit in metric? Thanks
  4. I WOULD LIKE THAT THE IMPORT AND THE EXPORT PROCEDURE BE MODIFIED WITH THE INDICATION OF THE NAME OF THE FILE AND THE FOLDER WHERE TO SEND OR RECEIVE THE TRANSLATION. FOR THE IMPORT IN ORDER TO BUILD A SCRIPT THAT SHOULD BE ABLE AUTOMATICALLY TO IMPORT AN EXTERNAL LIST OF SYMBOL {that is a large amount of small files). FOR THE EXPORT BECAUSE SEVERAL USER INSTEAD OF RECEIVING AN ELECTRICAL DIAGRAM WITH A NUMBER OF LAYERS DO PREFER TO RECEIVE SEVERAL FILES EACH ONE CONTAINING A SINGLE LAYER OF THE DRAWING FOR THE EXPORT CAPABILITY I RENEW MY WISH THAT THE PROGRAM SHOULD MANAGE SYMBOL WITH ATTRIBUTES EXPORTING THE SYMBOL EXCLUDING THE ATTRIBUTES AND EXPORTING ATTRIBUTES {THE ACTUAL VALUE NOT THE DEFAULT VALUE!!} ITSELF AS SIMPLE TEXT IN ORDER : -NOT TO LOSE ANY INFORMATION -NOT TO BE COMPELLED TO EXPLODE THE DRAWING THUS TRIPLING ITS SIZE. -PERMIT THE FINAL USER TO MAKE SMALL MODIFICATION MORE EASILY . MANY THANKS
  5. I would like to have the possibility to change the grid color. The current one is impossible to use with a black background Many thanks
