brvn Posted May 2, 2023 Share Posted May 2, 2023 I am trying to duplicate two Worksheets, place them on a Layer and move it to the right worksheet folder. I got it all working, except that the worksheets seem like they are not saved correct. If I want to activate the placed worksheet image in the resource manager, it doesn't work. Does someone have some experience ? Thank you very much # Script by Lukas Tobler | 27.04.2023 # Platziert die Tabellen automatisch auf allen Raumstudien und filtert den korrekten Raum import vs criteria_point = "(NOTINDLVP & NOTINREFDLVP & ((T=LOCUS) & (C='Hilfskonstruktionen')))" def create_tab_definition(handle_ref_tab, story): try: vs.NameObject(f"RST_{story}") folder_handle = vs.BeginFolderN(18) ws_handle = vs.CreateDuplicateObject(handle_ref_tab, folder_handle) vs.EndFolder() return ws_handle except: folder_handle = vs.GetObject(f"RST_{story}") ws_handle = vs.CreateDuplicateObject(handle_ref_tab, folder_handle) return ws_handle # Pro Geschoss (UG04-OG04) einen Ordner erstellen mit dem Namen "RST_Geschoss" (zb "RST_UG03") # Falls Ordner schon vorhanden, dann den Handle von diesem Ordner wiedergeben # Kopie von Tabelle "Vorlage Räume" oder "Vorlage Türen" erstellen und im Ordner speichern def main(point_handle): layer_handle = vs.GetLayer(point_handle) layer_name = vs.GetLName(layer_handle) if "RST" in layer_name: def get_ttb(h): global ttb_handle ttb_handle = h vs.Layer(layer_name) vs.ForEachObject(get_ttb, "((PON='Title Block Border') & (L='"+layer_name+"'))") story = layer_name[19:23] record_handle = vs.GetRecord(ttb_handle, 2) ttb_field = vs.GetRField(ttb_handle, record_handle.name, "Sheet Title") seperator_index = ttb_field.find(" /") room_number = ttb_field[:seperator_index] insertion_point = vs.Get2DPt(point_handle, 1) handle_ref_tab = vs.GetTopVisibleWS() if handle_ref_tab.name == "Vorlage Räume": new_tab = create_tab_definition(handle_ref_tab, story) vs.SetWSCellFormulaN(new_tab, 1, 2, 1, 2, room_number) vs.CreateWSImage(new_tab, insertion_point) vs.SetName(new_tab, room_number) else: new_tab= create_tab_definition(handle_ref_tab, story) insertion_point = (insertion_point[0], insertion_point[1]-0.185) vs.SetWSCellFormulaN(new_tab, 1, 2, 1, 2, room_number) vs.CreateWSImage(new_tab, insertion_point) vs.SetName(new_tab, f"{room_number}_Türen") vs.ForEachObject(main, criteria_point) Quote Link to comment
twk Posted May 3, 2023 Share Posted May 3, 2023 I noticed that in your code, the try and except block within the create_tab_definition function may not work as intended. Vectorworks won't actually throw an exception if the object name already exists, so the except block might never be executed. Instead, you could check whether vs.NameObject(f"RST_{story}") returns a valid handle (i.e., not [0, None]) to determine if the object already exists. If it does, you can simply retrieve the handle and create the duplicate object within the existing folder. Here's an updated version of the create_tab_definition function with this check: def create_tab_definition(handle_ref_tab, story): rst_handle = vs.NameObject(f"RST_{story}") if rst_handle != [0, None]: folder_handle = rst_handle[0] else: folder_handle = vs.BeginFolderN(18) vs.NameObject(f"RST_{story}", folder_handle) vs.EndFolder() ws_handle = vs.CreateDuplicateObject(handle_ref_tab, folder_handle) return ws_handle The other thing that I havent tested, or come accross is using the vs.CreateDuplicateObject to duplicate resources. Does that actually work? I will try later. Quote Link to comment
brvn Posted May 3, 2023 Author Share Posted May 3, 2023 Hi Thanks for this neat solution. I have noticed that vw doesn't throw actual error, but thought I'm dealing with it later. I got the vs.CreateDuplicateObject function working as following vs.CreateDuplicateObject(h, vs.GetParent(h)) 1 Quote Link to comment
twk Posted May 4, 2023 Share Posted May 4, 2023 there is an error in the code, the line should be instead: if rst_handle not in [0, None]: <... rest of code here ...> Quote Link to comment
