RitchieTheBrit Posted April 16, 2023 Share Posted April 16, 2023 Still tinkering. This time I have cobbled together a custom node to run VS:BuildResourceList2. It seems to work fine, except the SUBFOLDER option. The search doesn't appear to ever be limited to the subfolder. I want to limit the list to a very specific folder in the document resource library. Is this behaving correctly? #Modified by RB April 2023 @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( "List Resources" ) this.SetDescription( 'Builds a list of resources based on the OIP input' ) #Input Ports #OIP Controls ObjectTypeIn = Marionette.OIPControl( 'Object Type', Marionette.WidgetType.Int, 0) ObjectTypeIn.SetDescription('Integer that corresponds with Vectorworks Object Type') FolderIndexIn = Marionette.OIPControl( 'Folder Index', Marionette.WidgetType.Int, 0) FolderIndexIn.SetDescription('Integer that corresponds with the folder name constants') SubfolderIn = Marionette.OIPControl( 'Subfolder', Marionette.WidgetType.Text, 'Textures') SubfolderIn.SetDescription('Limit the list to the contents of this subfolder') DefContentIn = Marionette.OIPControl( 'Default Content', Marionette.WidgetType.Bool, False ) DefContentIn.SetDescription('Tick to enable default content') #Output Ports list = Marionette.PortOut('List') list.SetDescription( "List of the specified resources" ) #BEHAVIOR def RunNode(self): #functions #inputs #script ResType = self.Params.ObjectTypeIn.value; # The resource type: https://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix_D FolderIndex = self.Params.FolderIndexIn.value; # The index of the folder path: https://developer.vectorworks.net/index.php/VS:BuildResourceList2 SubFolder = self.Params.SubfolderIn.value; # A subfolder of the folder path to which the list is limited DefContent =self.Params.DefContentIn.value; # Toggle display of default content resList = [] # Populate the resource list resListID, numItems = vs.BuildResourceList2(ResType, FolderIndex, SubFolder, DefContent) for i in range(1, numItems + 1): resList.append(vs.GetNameFromResourceList(resListID, i)) #outputs self.Params.list.value = resList Quote Link to comment
RitchieTheBrit Posted April 16, 2023 Author Share Posted April 16, 2023 I've tidied the node up a little. I still can't understand why the SubFolder doesn't do anything. https://developer.vectorworks.net/index.php/VS:BuildResourceList2 List Resources.vwx Quote Link to comment
