beam
1-is there any other way of seeing the real beam of a specific lamp than having to use Renderworks and putting in a gobo and stating a beam angle but no gobo type for the lamp.
2-how do i get the x value of the position of a lamp on a pipe to print in a report so that my electrician can hang the dam lamps in the right places
You can see a wireframe representation of the beam without renderworks. The steps on how to focus an instrument are found in the manual.
As for the x co-ordinate of the lights, check out Kevin Moore's response on using a worksheet.
Kacey Fisher
Quality Assurance Specialist
Integrated Products Group
[This message has been edited by kacey1 (edited 08-10-2001).]
quote:
Create a new worksheet
Click on the lefthand side of the ws on one of the row buttons and hold down. A pop-up menu appears that lets you choose whether row is a spreadsheet row or a database row.
Choose database row.
For the criteria choose 'Record' 'Lighting Device' is 'Attached' then click ok
In the worksheet select column one of your new database row and enter:
='Lighting Device'.Position
In column two enter:
='Lighting Device'.'Unit Number'
This is the magic part, in column three enter:
=XCENTER
You might need to change the cell formatting of column three to get it to format as feet and inches or whatever.
Chapter 16 in the User's guide has info on worksheets. Check out pgs 16-10 to 16-16 in particular for further details.
HTH
Kevin Moore
Product Manager
VectorWorks SpotLight
<kmoore@nemetschek.net>
