snort
    7
Everything posted by snort
  1. Hello, When I try to print out my really basic light plot on an HP Deskjet 5440 in black and white it comes out as a bunch of squares and very pixelated... is there any explanation for this? any help is greatly appreciated. cheers.
  2. No I have not upgraded recently... I will do that. Another question though, if you do not mind... how do I get the Lighting Fixture Packages in the VW folder into my resource browser?
  3. i got it to work! when i switch over to the isometric drawings it is automatically switching in layers to something called Group #1. But the odd part is that the layer group 1 doesnt exist. is there anyway to avoid it from switching over? Also additionally, every time I start up VW it has this Gray texture over all the draftings, I restart it about 4 times before it becomes normal with out any texture over the whole page... any ideas? thanks for all the help.
  4. thanks! select all did not work... from all views in isometric the walls are completely missing. Even though I am making them in 2d right above the Groudplan. Bugging the heck out of me... any other ideas?
  5. Hello. I am working on the basics and have made two simple walls in my 3d view w/ the groundplan... the wall height is set at Delta 12' and then after the construction of the walls I switch to the isometric visual and the walls just are not there... why is this?
  6. I am not using the class attributes and even then all the attributes are set to visible... additionally I have just discovered that when I change the fill to None the line or object just becomes invisible and the object under it are still not visible...
  7. So when I try and set a line's attributes to dashed it automatically turns it completely transparent and is completely invisible. I have tried fussing over it forever and cant figure out how I could possibly be doing something so simple wrong... any ideas on this? any suggestion is appreciated!
