alfresco
241 -
Posts posted by alfresco
Spot and area lights are working but not a line light for a linear fixture? Any suggestions?
thanks
lm
Once the corrupt wall was deleted the auto hybrid worked as expected. Thanks for all the help!
lm
Allan,
Thank you very much for your time and assistance. I was unable to establish the cause for the auto hybrid failure. This is a very good learning experience and I will review the material posted.
Greatly appreciated!
lm
Hello
File attached. If you find any problems...
thanks for all your assistance!
I have created a Polygon, used clip surface and created an extrude. I want to model a vanity with counter with a cut out for a sink. I am unable to crete an auto hybrid? I am not sure why, but I get an error message referring to a poly break with the name auto hybrid already exists in document? Why can I not create an auto hybrid?
thanks,
lm
thanks,
lm
Thank you very much for your assistance, and you were correct with multiple files! VERY interesting and good tip!
cheers,
lm
That is correct. The resource is in the current file. However, it would appear that my only option is to create a new resource. I simply would like to edit the existing resource? Thanks..
I am am using VW 2017 and am unable to edit any texture, or tile etc in a file / resource manager? I am only allowed to create a new texture or tile? Why can't I edit?
thanks
lm
Jim,
Thanks, that worked! I am trying to under to understand the process?
I have just imported a 3D CAD drawing from a supplier. However the view orientation is incorrect. When I downloaded the file the view is indicating top/plan view, but is actually showing a front view? How do I correct this so that I may use in my current file with the proper view?
Thanks,
lm
I am rendering an interior renovation. I would like to create a mirror for the ensuite. How can I create a mirror that actually functions as one?
Thanks,
lm
Yeah. That is what I have been trying to do. I am in 2D component of the symbol but I cannot update. Strange!
I have text within a symbol that will not update regardless what is indicated in the attribute pallet. The pen colour remains black even though the colour is blue in the attributes pallet. I can toggle between defaults etc with no change to the pen colour. How to get the symbol text to update? thanks.lm
Tim,
Correct, That was the issue. The 3D portion of the symbol was not updated to reflect 2D geometry. Thanks!
I am working on a kitchen design. I have down loaded a sink symbol. I line up the sink and counter top which has a cut out for the sink in plan view. I also set the the elevation correctly. When I view in a perspective the sink symbol does not line up properly. It is offset from the counter top. Why would the symbol line up in plan view but not a perspective?
thanks,
lm
Thanks,
I would like to insert a window dormer in to my roof. When I create a window symbol the dormer is created. However the window orientation is not correct. It is perpendicular the wall. How do I change the orientation or change insertion operations?
thanks
When I go to libraries Defaults, I can select walls-slab- roof- textures etc. However there are no wall styles listed?
thanks, lm
I am using VW2016. I want to save a wall style to my user folder. However, wall styles are not listed? Suggestions?
thanks
lm
Thanks,
I have tried a number of things. I have noticed that when I try to set the class to a wall style i am creating it defaults to a unstyled wall with corresponding attributes?
Just getting started in 2016. Created a new wall style, however graphic attributes such as line colour not responding correctly?
Thanks
lm
Just downloaded 2016. What happened to standard projections? Front / Right Perspective etc..? View Bar change?
Line Light
in Rendering
Posted
I am not familiar with with glow shaders or the custom IES lights? Where may I find the shader and IES lights?
Thanks for your time and suggestions,
lm
