Thanks for the advice, I have created a design layer @ 1:1 scale and have assigned the selected title block to this layer, however when i try to scale down the text to 1:1 size it only does part of it. The part that scales down ok is a the company graphic that i presume was just imported into vectorworks and is not editable, except it seems for scaling, the other parts of the block do not want to scale down. there are no lines or boxes, only two simple line of text but when i attempt the same procedure as carried out on the graphic it just jumps to the right.
Also, i am setting up the template so it covers all the main scales, but had noticed that the graphic block changes to a grey rectangle when on a different layer and prints like this, also the weight of the other layers is reduced. If you could tell me what i am doing wrong as there are obviously going to be instances where i need to set up a page with one drawing @ 1:50 and one @ 1:5 etc each on different design layers and i need them to print the same!
Thanks again for your help, much appreciated!
