Cheth
19 -
Reputation
0 NeutralPersonal Information
Location
United States
I am sort of having a bit of an issue with encryption. I have attached an image of what is happening after I encrypt. I try to run the plug in and i receive an error that vs module is not built in, so i added it from the sdk to the folder with all my includes and updated the xml file. same error pops up after encryption. Any thoughts?
TWK FTW. Thank you. I was pulling my hair out trying to understand how to reference criteria in python.
I seem to be trying the same thing over and over again. I am trying to understand vs.ForEachObject criteria in terms of python. For example, if I take this script in vectorscript Var Light: Handle; Procedure setname(conventional:Handle); Begin SetRField(conventional,'Lighting Device','Symbol Name','Conventional'); End; Begin ForEachObject(setname,(((PON='Lighting Device') & ('Lighting Device'.'Device Type'='Light')))); End; Run(setname); And I want to move it to Python... I only get as far as, import vs; def setname(h): vs.SetRField(h,"Lighting Device","Symbol Name","Conventional"); vs.ForEachObject(setname, ????) I can't figure out the syntax to check for the device type in a lighting device that is equal to a value of Light. I error out every time.
Pat you are absolutely the best, is there an easy way i might be able to compensate you for your time?
I am working on my Digital Lighting Library, and giving my DL's the proper rectangle output by using shutters and drawing the beam as a solid. For some reason, one of my shutters does not cooperate. Is there something I am missing? see attached files for explanation.
Pat! I came across your name on the boards the other day and meant to PM you as you seem to know what you are talking about. I had forgotten to do so. Anyway, no, you are right, however, I thought with as concise information I provided, that it would be okay to assume that I already knew how to do this manually. I did ask for exactly what I wanted. I was hoping someone knew how to do it off hand and didn't have to do much work but write a few lines of code and I would be on my way. To answer your question, this is something I do for Every show that comes across my desk, (at least 3 to 5 a day) I can get into the details with you privately, however I'd prefer the details of the project to be on the down low. Which is the reason I asked for something quite specific without going into detail about the overall project. Let's chat privately if possible, we could talk compensation for your time as well.
I appreciate your responses, however, can we assume since I am coming to the board (which I never do), that I am asking for what I need? I am having problems finding time to figure out the code to do what I am asking. I am trying to automate a process. If I need to hire a coder because I don't have the time to figure it out, then I will. I was just hoping for a quick answer to a question without the assumption that I want to do anything else but what I have asked. Hippothamus, I appreciate your offer of the tool you are working on, and I would love to look at it, maybe to just analyze the code and see how it works.
In short, and without trying to sound rude, I'd rather double click a script once than have to go and change the data in the OIP every time I work on these files.
Hey Guys and Gals, I am completely fried at the moment and need your help with a vectorscript Problem. I need a vectorscript that will select all instruments with a device type of 'Light' Then Change the field of Symbol Name to 'Conventional' Then Change the Rotation to '0' And finally move all objects to a Y Value of '0' I really appreciate any help.
The New USITT Standards for the Enhanced ERS are as follows. This is taken from the USITT Graphic Standards Publication that can be found at http://www.usitt.org/standards/StandardsList.html
Vectorworks doesn't like the fact that it is being "watched" by my antivirus software. Gave vectorworks full priveledges and adjusted the antivirus checks to understand that vectorworks is a trusted program. This seems to have solved the issue. Thanks for trying to help.
Alright: Yes I have tried restarting and trying again. the video driver has not been updated. At this point i am to the point of just uninstalling the program and reinstalling.
Doesnt really matter what symbol I use it still hangs when I copy and paste in any document i open, also happens in a new document when i have worked on it for about 20 minutes and i start copying and pasting and moving instruments it hangs. I am only copying one instrument so its not like im overworking the program by copying 90 instruments and pasting them at the same time.
