I'm sure this is old hat to you experienced users:
I have a rather large file of a subdivision with grading contours, streets, building pads, utilities, etc. This was a .dwg file which I imported into VW (12.5.1) then used to design common space landscaping. All is well with this part of the project.
Next, I received separate .dwg files of each of four different condo designs, which I imported into VW and used as the bases for the individual unit landscape designs for the builder's models. So far so good.
Now, I need to show these model footprints with their associated landscapes on their appropriate building pads in the master plan (which is already a very large file, incidentally).
Since I will ultimately, over time, be drawing the landscape designs for each of some 80 duplex condominiums, I cannot realistically plan to keep adding individual landscape plans to this master plan file. Is there a way to "excise" only the section of the master plan that I need for each condo?
Whew. Thanks for reading, and thanks even more for your advice. I hope I've explained my problem clearly enough.
