beanus
378 -
Posts posted by beanus
the "now printing" dialogue box appears & then everything grinds to a hault, I've turned off GDI & the drawing prints straight away, problem is the opacity effects are lost
I've just upgraded to windows 7 & i can no longer print with GDI on, I'm trying to print to a HP Designjet 500 - help
whats WGR trick from a new file?
the arrow heads wern't there to start with, they seemed to suddenly appear!
I've got a problem with the way the framing members are displaying (see attached)the arrow heads suddenly appeared, I have know idea how, can some on help. This has also happened with the roof object & the arrows also appear in the view ports
I use an Evoluent vertical mouse, has five buttons & is easy on the wrist, no 64 bit driver though
can anyone tell me what a good spec would be. My work computer is a Intel Xeon CPU 2.80 GHz, 2.79GHz, 2.00 GB ram. Display adapter is NVIDIA Quadro FX 540. This seems as if it should be a fast computer but is slow copared to my home computer which is a lower spec especially when refreshing, panning or zooming. I would be gratefull for any sugestions.
I've created a circular window & inserted it into a wall as a symbol, is it possible to attach an ID label to it as with normal windows?
I usually use Sketchup & import into Vectorworks for any thing complicated, I've not got the hang of 3D modelling in Vectorworks yet, but I am getting there.
yep I've had this happen too!
is it worth upgrading to 2010 yet, have all the bugs been sorted out, there seems to still be a lot of them according to the forums.
the menu item is greyed out, does this mean i need renderworks?
how do i export a file to Piranesi?
I've had this problem as well, the design layer displays correctly but the viewport does not, if I go into the design layer from the viewport & then back to the viewport the windows & doors display correctly but if I close the file & open it again the problem returns, see attached pdf
haw do i make a group of 3d polygons into a solid?
gimme, gimme, gimme
is there a way to make windows only spaly jambs & not the head & cill as well?
oh! soory to be a pain
I've just realised its only multiple or grouped objects that disappear & I can only see a box that marks the area of the selected objects, single ones are OK apart from callouts, the text disappears, is this normal?
all the time, sometimes bits of the objects are visible especially callouts. I use vectorworks on two different computers with different OS & spec & its the same on both
through HPs own updating system
yes all up to date!
when I drag an object or a group of objects with the mouse they disappear, is it possible to make the objects stay visible
GDI & printing
in Architecture
Posted
all the the items under the advanced tab are greyed out, see attachment
