beanus
378 -
Posts posted by beanus
cant get the walls to display with the class colours in section viewports, I've attached the file this keeps happening
cant get the ID label to to work correctly is this a bug? it used to work but now the labrels are put in odd positions, the text size varies & the text colour isnt what I set it to - HELP
its OK I've sorted it
cant stop 'duplicate along path tool' from offsetting the first copy even though I've set the preferences not to, am I doing something wrong?
haven't solved the problem because if I open the file again in 2009 it displays incorrectly again!
I exported the the file to 2008 & the section displays correctly see attachment
didn't work!
thanks I'll give it a go.
does this work for the open file dialog box within vectorworks?
is it possible to add short cuts to the "Open" file dialogue box, see attachment
the section has changed again, see atached,
I'm having problems with class styles not displaying correctly with in viewports (see attatchment), they display fine in plan view its only in sections that I get the problem, it seems that sometimes one class style will override another, any one else had this problem! is this a bug?
Thanks it works, what did you do to the file?
thanks but still cant open the version 12 file in 2009
every time I try to open this drawing which was created in version 2008 in version 2009 the program crashes, can anyone help. I've attached the drawing
how do you turn on the scale option
I agree the view changes are a pain!
I find V2009 slower & unstable especially when it comes to 3d modelling, things I could do in V2008 causes V2009 to crash also the sanp loupe tool sometimes works, I think the only good thing about V2009 is the positioning of doors/windows. Hopefully there will be a patch to sort things out until then I'll be using V2008
any idea what these hiddedn lines are?
I seem to get some strange resulults when I use the "polygon from inner boundary" tool (see attachment) 2008 was much better
in 2008 if I held down the AltGr key (right hand side of the keyboard) while using the 2D reshape tool I could draw a polygon around the points I wanted to stretch but now in 2009 to do the same thing I have to hold down the Alt key (left hand side of the keyboard) along with the shift key, is it possible to change it back to the way it was in 2008
cant get the snap loupe to work in viewports, everthing disappears when you zoom in with "snap loupe" help!
when I press the alt key I firstly get the lassoo symbol come up but as soon as I move the mouse it changes to an eyedropper with a star next to it & I have no idea what this is???? which Alt key do you hold down it always used to be the right hand one
cant get the 2d reshape tool to work now while holding down the alt key (lassoo mode), it used to work fine in 2008, whats happened?
section viewports
in Architecture
Posted
thanks for trying
