RWRussom
    3
    Never
Everything posted by RWRussom
  1. Yes, I've tried that, but it seems I will have to adjust or create a new for each change in cabinet size. Is this correct or can a texture change size to fit as required. Randy Russom
  2. is it possible to have a image based texture strech to cover the full plane of a surface. My thoucht is scanning in a cabinet face and assigning it a style. It seems I use to be able to do that with RW8 but with RW9 have not found a way. Thanks Randy
  3. I had the same problem/question about two weeks ago. The previous post was what I used to do before I bought Architect. I wanted to utilize some of the features in the automated titleblocks but still use my custom block. This is what I did. I typically use the same sheet size every time, archD. I went in and modified the and modified the title block object that VA setup pulls from. This can be found in vectorworks/toolkit/obects. Open 00_Arch_Sheets.mcd. Use resource pallete to select sheet/symbol to modify, select edit. Make your changes. Exit symbol. Exit drawing and save. I suggest saving a copy of the original 00_Arch_Sheets.mcd to revert to if you screw the whole thing up.
