I've been doing what you suggested but without luck. The image never reduces on the screen to fit the 11 x 17 outline. What is represented in the 11 x 17 box does reduce but I can't seem to get the printer to acknowledge the whole drawing. I installed the printer after VW and wonder if I should try installing the other way around.
quote:
Originally posted by RGyori:
I use the 1120C on my Mac G3 as follows:
In FILE menu PAGE SETUP dialog select the appropriate sheet size and orientation and change the size factor to 44% (at least this percentage works for me), then go to the PAGE menu SELECT PRINT AREA... dialog and click on one page. The 24 x 36 document should now display within the boundaries of an 11 X 17 sheet.
