HB
    2
    Never
Everything posted by HB
  1. HB
    Scaling
    I've been doing what you suggested but without luck. The image never reduces on the screen to fit the 11 x 17 outline. What is represented in the 11 x 17 box does reduce but I can't seem to get the printer to acknowledge the whole drawing. I installed the printer after VW and wonder if I should try installing the other way around. quote: Originally posted by RGyori: I use the 1120C on my Mac G3 as follows: In FILE menu PAGE SETUP dialog select the appropriate sheet size and orientation and change the size factor to 44% (at least this percentage works for me), then go to the PAGE menu SELECT PRINT AREA... dialog and click on one page. The 24 x 36 document should now display within the boundaries of an 11 X 17 sheet.
  2. HB
    Scaling
    How do I reduce a 24 x 36 drwg down to 11 x 17 using an HP 1220 DeskJet. I'm using Vectorworks 8.5 on a PC.
