Joshua Thatcher
    6
Everything posted by Joshua Thatcher
  1. Hopefully this link will get you to the right page on Martin's website. There drawings are DXF or DWG, but wll be a good start. Once there under "Category" select "Illustrations" http://www.martin.com/service/service.asp?dofind=yes&support=Martin
  2. Have double checked and rechecked the NVidia website. They have an update but it does not apply to my machine. I did however uninstall the drivers completely off of the computer and reinstalled them. Performance has increased. No crashes today. Thanks to everyone for your input.
  3. I have checked all of those types of options. The machine is 3months old and all of the drivers are current. I have checked them myself. I have also reinstalled the drivers to see if there is a change. So far no difference.
  4. I have started using a Sager Laptop for my designs. It has crashed with Vectorowrks since the beginning. It usually happens after a series of nudges or changing serveral perameters one after another. It freezes so hard that the computer locks up even after I finally get Vectorowrks to Shutdown. I check my running progams staus info and it says that the CPU usage of Vectorworks is in the range of 97 to 99%. I have left for up to 30 mins to see if the problem resolves itself and gives me message of any sort. I eventually have to hard reboot the machine. I have run Vectorowrks with a lesser quality Laptop aand it runs fine. HELP!!! My Specs are as Follows: Vectorworks Designer 12.5 Windows XP Home - Version 2002 - SP2 AMD Turion 64 Mobile Technology ML-44 2.41 GHz , 2GB Ram Dual NVidia GEForce Go 7900 GTX Graphics Cards
  5. Does the idea of a titleblock object similar to the lighting object sound like a good idea to any one? That way you could create a block object and have a manager like the label legend manager in Spotlight. You customize it several times in the same drawing just by having a diferent legend assigned. In the label legend you can tell the text to wrap and it will.
