Assembly
430 -
Posts posted by Assembly
I use time machine. Excellent.
I have three portable hardrives.
One sits constant on the main computer.
One is in a safe.
One comes home.
Each time you switch out your hardrive reset the Time machine to the reinstalled drive. It is easy.
If you have a small amount of data and lots of bandwidth dropbox.com is a good option.
Store your files in the dropbox. Keep one of your old machines offsite with a linked dropbox. This keeps copies in your local drive, the cloud, and anywhere else you have another link. Caution though if you delete a file in one location it removes it from all. However if you add a Timemachine drive to the remote computer then your covered.
As a note on dropbox- we have a shared VW preference folder stored in our drop box. This means that when one person adds a favorite file, or creates a new plug in it updates all the workspaces in the office.
Function Profile2DrawType1(VAR ProfileRepeats: Real):Handle;
BEGIN;
Rect(0,0,300,10);
Profile2DrawType1:=LnewObject;
ProfileRepeats:=310;
END;
Function SelectProfile2ExtrudeAndRepeat(Profile:Handle):Handle;
BEGIN;
hTemp:=hExtrude(Profile,0,100);
hDuplicate(hTemp, ProfileRepeats,0);
END;
__________
Used like this:
HTemp:=SelectProfile2ExtrudeAndRepeat(Profile2DrawType1);
Sorry, I was not clear, As you point out Pat I should have had the VAR.
Here is the problem...
When Profile2DrawType1 is called in SelectProfile2Extrude I can't figure out how to fetch the RepeatProfile value from inside the SelectProfile2Extrude function.
The SelectProfile2ExtrudeAndRepeat(requires a Handle to Draw). Profile2DrawType1 draws a shape and gives it a handle.
This works fine the extrude is created.
BUT, as I use the Profile2DrawType1 inside the variable settings of SelectProfile2ExtrudeAndRepeat-
HTemp:=SelectProfile2ExtrudeAndRepeat(Profile2DrawType1);I don't see how to get the value through.
Thanks everyone. New problem.
I want to use a function to pass an handle and real inside another function.
Something like this: (Miguel I do check for NIL but striped for quick reading)
Function Profile2DrawType1(ProfileRepeats:Real):Handle;BEGIN;
Rect(0,0,300,10);
END;
BEGIN;
END;
__________
Used like this:
This works to draw the profile to extrude.
But I don't know how to to get the value returned for the ProfileRepeat value.
Can anyone help me... with this?.
Acrobat Reader has the ability to present 3D in PDF.
Anyone know if VW is able to export 3D components to PDF?.
GetBBox(hLine,x1,x2,y1,y2);
MEssage('x1:',x1,' x2:',x2,' y1:',y1,' y2:',y2);
Can someone else test this.
Documentation states:
But I am getting:
GetBBox(hLine,x1,x2,y2,y1);
That is the Y2 and Y1 are reversed.
The result of this function, inside a PIO creates and 'exploded' bunch of nurb surfaces.
Using the menu extrude along a path creates a solid extrude.
Major difference.
Who knows how to make an exturde along a path that remains and extrude thus allowing further add / subtract functions to happen?.
VSFR has a good replacement for hExtrude.
How Orso figured this out to start with is genius.
{ ***************************************** }{ Orso.B.Schmid, creates an extrude from a HANDLE h,
preserving the original h. Returns a handle to the extrude }
FUNCTION Create3Dobj(h: HANDLE; z, dZ: REAL): HANDLE;
BEGIN
IF h <> NIL THEN BEGIN
BeginXtrd(z, dZ);
LineTo(1, 1);
{ just draw something for creating an extrude container }
EndXtrd;
DelObject(FIn3D(GetParent(CreateDuplicateObject(h, LNewObj))));
{ places a copy of h in the extrude and deletes the line }
Create3Dobj := LNewObj;
END;
END;
BUT there is a minor bug in the code above.
The object extrude uses LineTo(1,1);
If the cursor is already at (1,1) then the line is not drawn and the extrude is not created.
Easy fix is this:
BEGIN
BeginXtrd(z, dZ);
MoveTo(0,0);
LineTo(1, 1);
EndXtrd;
END;
END;
Orso If your out there you might update VSFR.
Thanks
he exact direction I needed
thanks indeed!
This is what I'm after in the most simple terms.
I want my function to return more than one Variable.
IE
FUNCTION DrawShapeGiveHandle(AndReturnWidth:REAL): HANDLE;
BEGIN;
Rect(0,0,1000,100):
DrawShapeGiveHandle:=lNewObj; {this gives me a handle to my shape}
AndReturnWidth:=1000; {this returns the width of shape}
END;
So I can do something like this
hTemp:=hDuplicate(DrawShapeGiveHandle(RealTemp),RealTemp,0);
This would allow me to duplicate the shape and return the width to space the duplicate all in one handy function.
I want a to be able to pass more than one value out of a function.
A handle and a Real.
GetBBox returns multiple values.
Can anyone show me how this works?.
I want to make an object that starts with a selected polygon similar to what the Floor Menu Tool does.
Can some start me off here. I don't get how you get a handle to the object that is selected prior to running the script.
Thanks
James
What does this do?.
What is your application?.
has anyone been able to append a popup widget to the OI and add a selector.
I have the pop up on my OI but no idea how to add selections.
Any model view - Section Elevation or Perspective should be able to set line weights based on distance from viewing point.
Objects should be able to have a render Hatch.
The 3D Hidden line rendered drawing should not require any touch ups.
The BASE Level object always uses a Number as the Variable.
IE
Width:=pWidth;
Depth:=pDepth.
The SECOND Level object uses a pop up selector and creates the logic of how to size the BASE object.
ie
IF pPopUp='200x50' Then
Begin;
SetRfild(pioName,PIOHandle, 'Width', 50);
SetRfild(pioName,PIOHandle, 'Depth', 200);
Here is a good one for you PIO developers.
FindAndReplace will find all of an old PIO and insert a new version.
It would be great if some one with a bit of dialog experience could wrap one around this....
PROCEDURE SHELL;
{*/ This Procedure will searh a file and upgrade all instances of a PIO
It can be used for PIO's that have the same parameter Names
PROCEDURE FindAndReplace(oldPIOName:String;upgradeName:String);
PROCEDURE FindReplace(hObject:Handle);
VAR
x1,y1:Real;
hLayer:HANDLE;
LayerName: STRING;
NewObject: Handle;
hNewObject:Handle;
recName:String;
recHand:Handle;
Cnt:INTEGer;
fldName:STRING;
PassText:String;
BEGIN;
GetSymLoc(hobject,x1,y1); {*/Get insert point of existing PIO}
hLayer:=GetLayer(hObject);
LayerName:=GetLName(hLayer);
Layer(layerName); {*/Change to the layer of the Existing PIO}
hNewObject:= CreateCustomObjectN(upgradeName,x1,y1,0,False); {*/Inserts the new Object over the old one}
recName := GetName(GetRecord(hObject, NumRecords(hObject))); {*/Get Record Name of existing PIO-This is entered anyway}
recHand := GetObject(recName); {*/Get Handle to Record}
FOR cnt := 1 TO NumFields(recHand) DO BEGIN {*/For each of the parameters in the object}
fldName := GetFldName(recHand, cnt); {*/Get the Parameter Name}
PassText:=GetRField(hObject,recName,fldName); {*/ Get the Value}
SetRField(hNewObject,upgradeName,fldName,PassText); {*/ Pass the Value into the Parameter of the New Object}
END;
END;
Begin;
ForEachObject(FindReplace, INSYMBOL & INOBJECT & INVIEWPORT & (PON=oldPIOName));
END;
BEGIN;
FindAndReplace('NZ Master Spec Note','NZ Master Spec Legend');
END;
Run (SHELL);
{Code Written By Justin Wright 2010}
{This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see .}
The object is a 3D wall detail tool.
Essentially it draws a timber framed wall with all its parts.
Draws Timber Floor Framing
Draws Timber Flooring
Draws Timber Wall framing
Draws Building Wrap
Draws Cavity batten
Draws Cladding
(we can add most cladding types in about 5mins);
Draws Window
Draws Flashing Tape
Draws Sill & Head Flashings
Draws Claddings
Draws Timber Rafters
Draws Roof Underlay
Draws Roofing
Draws Gutter Flashing
Draws Gutter Profile
It is completely parameteric allowing for any roof pitch, height, frame size, window size.
Nesting.
Level 1
Single pane of glass.
Double glazing spacer
Level 2
Double Glazing Unit.
Uses above to make a DG unit.
Level 3
DG goes into a Window Object.
With
Aluminum Window Profile Extrusion
Level 4 Window Component Object ready for wall.
Adds Head Flashing
Window liners
Sill heights.
Allows for adjustment of object to fit in the depth of the wall.
Level 5
The Wall object itself
This has over 100 parameters
Next Step is to create a 6th level object that simplifies the parameter interface to reduce the number of settings
If you want to load use an external file use the XML functions.
Here is a snippet to get started.
When you script is executed you will want to write to the XML file
what the old class was and what the new class is
When you load your script you will want to load the XML file and see if there are any classes to be reassigned with defaults if so set the default.
___________________
PROCEDURE GetXML;
CONST
kLibraryFolder =-13; {constant to set the file path to the VW library folder}
VAR
hXML :LONGINT;
xmlFile :STRING;
result :INTEGER;
BEGIN;
hXML := InitXML;
IF hXML <> 0 THEN BEGIN
xmlFile := 'ClassAssign.xml';
result := ReadXMLFile(hXML, kLibraryFolder, xmlFile);
DATAPath:=Concat('/Prefs/',ClassName[]); {defines the classname path, upto you how to this is structured.}
result := GetElementValue(hXML, DATAPath, NewClassName[]));
{this will return the value to NewClassName[]}
result := ReleaseXML(hXML);
END ELSE BEGIN
SysBeep;
Message('Could not initialize XML reader.');
END;
END;
a couple snippets.
Place this just after you text creation
GetBBox(lnewobj,x1,y1,x2,y2);
Moveto(x1,y1);lineto(x2,y1);lineto(x2,y2);lineto(x1,y2);lineto(x1,y1);
This will draw a tidy box around your text.
3. Yes you can insert PIO inside other PIO and adjust the parameters. If you do you are treading in unchartered territory. I started a few posts mid last year. With little response from anyone...
Since then we have been using nested PIO extensively. Objects are nested 3-4 layers deep. I have found that 3D objects perform better than 2D. Sometimes 2d lines don't generate. It can be a bit buggy, but I have found this technique very useful.
Here is the general layout of how it is set up:
VAR
ObjectName:STRING;
HObject: HANDLE;
DadVar: REAL;
MumVar:STRING
GrandMaVar:Boolean;
ObjectName:='The_PIO_You_Will_Install';
HObject:= CreateCustomObjectN(ObjectName,0,0,0,False);
SetRField(HObject,ObjectName,'VarNameOfChild1_Int',Num2Str(1,DadVar));
SetRField(HObject,ObjectName,'VarNameOfChild2_Str',MumVar));
Note use of Num2String.
All values passed to your child PIO need to be passed as Strings.
Now where you will often trip up is getting the parent and child variables mixed.
VAR
GrandMaVar: Boolean;
SetRField(HObject,ObjectName,'VarNameOfChild3_Boo',GrandMaVar));
This will not work.
VarNameOfChild3_Boo is a Boolean.
and GrandMaVar is Boolean
BUT you must always pass a STRING in.
GradMaVar which is going to be used to control the Boolean in the child needs to be a string in the Parent
GrandMaVar:=True; {Boolean}
is ver different to
GrandMaVar:='True'; {String}
Get it?.
Thanks Kevin
I did manage a hack
If lScale<2 THEN Textwidth:=lscale@50 ELSE Textwidth:=500;
will put on the list of things to check
Hitting this again.
Is there a way to find out if a PIO is inside a symbol?.
Symbols are creating trouble with text wrap width.
Thanks Miguel
I can't find a way to fully automate generation of PDF. I was thinking i could do this through SDK, from your explanation I am sure I can.
but;
time i have to learn c++:= NIL;
Still if there is a SDK guru out there I am sure there are a few scripters lurking here that would like to see a YouTube of how to set up and get going.
More testing.... Yes nested worked!
I did have a the include file structure looking like this:
{$INCLUDE /Dropbox/AssemblyScript/Plug-Ins/0TestShell2}
Which works fine inside the VW plug in script.
To get the nested path to work I changed it to
{$INCLUDE Lap13 HD:Dropbox:AssemblyScript:Plug-Ins:0TestShell2}
Okay good. BUT now I have a new problem.
I use Dropbox (www.dropbox.com) to sync my Vectorworks Setting across my three computers. Each computer has dropbox installed and sharing a folder VW 2009 Settings. On each computer I set the VW preference I set my user folder to this folder.
Hence
IF
I add a plug-in and edit my workspace on one computer
THEN
Dropbox updates the folders on the other computers- thus we have identical set up on all computers in the office by just changing one. This work a treat.
BUT
All my plugins use $Include with the file path: /dropbox/../../
if I go and change my file paths to using Lap13 HD:Dropbox:..:.. then as each computer has a different drive name I will have a different problem.
Bugger.
My apologies Raymond.
I thought reshaper was a code editor, haha.
http://www.jetbrains.com/resharper/beta/beta.html
Anyhow after your post I did research and am keen to try out your Reshaper. I emailed you.
Back to the nested $includes.
Can you please cut and paste your nested include path that is working. Then I can check my file path structure against yours.
Thanks
Export VectorScript Script?
in Vectorscript
Posted
Any one have a procedure that can export a files vectorscript with script.
