Kevin H.
    5
    Never
Everything posted by Kevin H.
  1. Thanks Katie! I really appreciate you and the others in tech support and training - no matter how desperate I sound when I call.
  2. Thanks Katie for responding. I did find an alternative as I mentioned in my response post to Petri this morning. Katie, in answer to your question, I am using a 5.35 version printer driver. I did talk to my plotter tech and he said that, even though a more recent version may be available, an upgraded driver will not make a difference in this case. I'm assuming that he feels this is a memory issue and the updated driver will have no effect on the problem. Is this not right? I appreciate your insight. Thanks! Kevin H.
  3. Thanks for your response Petri. After adding my post last night I found an alternative. I copied the worksheet and used the "paste as picture" choice under "Edit" to paste it onto the design layer. I then transferred it to the sheet layer via a viewport. It printed perfectly using the "rasterize" choice. It was my experience in the past that by just copying a worksheet onto a sheet layer without a viewport causes the worksheet to print much larger than the desired scale. Otherwise, Petri, I will try your approach with other items from the design layer to the sheet layer. Thanks again. Hope all is well in Finland! Kevin
  4. Hello I am using 12.5.1 Landmark on windows XP. I am printing to an HP design jet 800 24. The worksheet was transferred to the printing sheet via a viewport. All layers and classes within the viewport are checked to be visible. I have tried normal pringting and rasterized printing,since it's a fairly large design, but can't get the worksheet to print. Everything else, including the large,detailed colored landscape design, prints to the plotter without a problem. I have not had a problem in the past when using rasterized printing on large designs. The only difference I see is that I have updated from 12.0 to 12.5.1 since that time period. Hopefully, it's not the updated version. I appreciate any help. Thanks! Kevin hollylanddesigns@sbcglobal.net
  5. What happened to "Flower characteristic" in the plant reference data base? After downloading the lastest upgrade 12.1, I realized that "flower characteristic" when clicked will not provide any choices. This feature provided choices when clicked with the 12 version but now, will not work. Has this been deleted with the recent 12.1 upgrade? [ 02-16-2006, 08:26 PM: Message edited by: Kevin H. ]
