What is a Miscellaneous Error (20,2)?
I am trying to create a contour model, following the procedure in the manual and as recommended in previous posts. I use the Bezier tool to draw the contour lines, bottom to top; I convert them to polygons and then go through the Survey Input procedure to convert to 2D polygons to 3D contours.
Then I try to create a site model and get the message:
A miscellaneous error has occurred. (20,2)
No overlapping contours, no doubling back; all layers at 1: 100 and each 3D contour has a z value in the OIP when converted. What am I doing wrong? The error message gives no guidance at all and the online help appears not to list errors.
Any ideas?
Martin Dickie
Dickie Architects
VW 11.5 on a G4 PowerBook
