Vlado
Vectorworks, Inc Employee
    697
Posts posted by Vlado
  1. Hello,
    the VWFC classes are wrappers on top of the SDK. Unfortunately, not very well documented.
    The VWObjects namespace contains objects that are designed as wrappers of MCObjectHandle. Every class has two different constructors:
    1. wrapping - the one that accepts MCObjectHandle
    2. creating - the all others (they create a new object)
    For the VWRecordObj you can just create instance like this:
    VWRecordObj rec( hRecord );
    Note that for parametric objects, it's much easier to use VWParametricObj, it directly allows you to access the parameters.
  2. I'm not thinking of breaking or removing VectorScript. My thoughts are more for big project VS can be very clumsy. So, would a VS developer be inclined to switch in that case?
    I saw some people are already thinking SDK, but hesitate due to the complexity associated with C++.
  3. Hi there,
    I wanted to inform you that Vectorworks 2011 SP1 will fix the following functions:
    Get3DCntr
    AddVertex3D
    GetLocus3D
    CreateLocus3D
    GetLightLocation
    EvaluateNurbsSurfacePointAndNormal
    NurbsGetPt3D
    NurbsSetPt3D
    NurbsCurveEvalPt
    NurbsSurfaceEvalPt
    GetParameterOnNurbsCurve
    GetSymLoc3D
    Centroid3D
    CreateContourCurves
    GetObjExtentsInWall
    GetPt3D
    GetPtL3D
    these routines were overcompensating for layer elevation in the main release.
    The SP1 will have these working properly, returning z relative to the layer of the object.
    Regards,
    Vlado
  4. Technically, it is possible. If you want Win only plug-in it much easier because you can mix .NET and C++ in the same plug-in. But, still you have to do a lot of work.
    On Mac Mono is working great. I've testing it and it's working perfectly. Actually, you can compile with the VisualStudio and Mono will still run it without problems.
    The Vectorworks 2011 module plug-ins (http://developer.vectorworks.net/index.php?title=SDK) are designed to start solving the problem of calling .NET and C++. Also, VCOM system can be used to automate the calls between C++ and .NET
    Unfortunately, VectorWorks .NET plug-ins are in the future.
  5. Hi,
    the easiest way to start with the SDK is to see the samples. Vectorworks 2011 SDK contain few samples of plug-ins.
    1. Install XCode 3.2 on Mac and Visual Studio 2005 on Win.
    2. Download the Vectorworks 2011 SDK
    3. Inside the SDK zip file you'll find the samples. You should be able to compile the samples right out of the box.
    4. Note! in order to run the samples in VW you need to have a short-cut (alias) in your Vectorworks' application 'Plug-ins' folder to the SDKLib output (there will be an output folder created when you compile a sample)
    Also, in the Vectorworks SDK under WinTools you can find a wizard for the VisualStudio that will help creating plug-in projects.
    I hope we'll be able to create more step-by-step samples or video one day.
    Regards,
    Vlado
  6. Hi all,
    here you can find the new Vectorworks 2011 SDK routines.
    http://developer.vectorworks.net/index.php?title=SDK:Vectorworks_2011_New_Functions
    Note that as of Vectorworks 2011 the SDK has a new Plug-in Module system for extending Vectorworks.
    See for more details here:
    Plug-in Modules
    They are not terribly well documented, but with the time I hope they will. You can register and help out proving the information for each function. Please note that this site is not comment driven. The information for each function should be 100% valid, not opinion based.
    Let me know if you have comments or questions: vstanev@vectorworks.net
    Regards,
    Vlado
  7. Hi all,
    here you can find the new Vectorworks 2011 VectorScript routines.
    http://developer.vectorworks.net/index.php?title=VS:Vectorworks_2011_New_Functions
    Regards,
    Vlado
  8. Hi Mark, are you still fighting with this?
    Anyway, open the cproj file as text file and change the path to NNA_GlobalBuild.vsprops, the correct one is:
    ..\..\..\SDKLib\Include\OnlyWin\NNA_GlobalBuild.vsprops
    Regards,
    Vlado
  9. Having studied the problem, what is ocuring is a bit more baffling:
    I place a road or anything with modifiers and a fence send it to the surface then update the site model. It come s up with error report that 2 pads overlap and a pad and a fence overlap, i close the dialog box. The contours in 2D?plan view have been adjusted ok and seem to have worked, BUT when a 3d view is selected and rendered the old profile remains.
    Have you selected to show proposed model in 3D too? Obviously you have set to show proposed model in 3D, that's why you see the contours change, but you have to explicitly set it for 3D so you see the changed model.
  10. It is VW 12.0.1,
    Is there any reason why a road, when the modifiers work, could not be used to illustrate a river? Can you vary the width of a road section so it slowly get narrower?
    Well, the road object cannot change width, that because of that cannot be used for representing a river. You can make one 3D polygon representing the river and set it into the Modifiers class. This way the Site Model will recognize it as modifier (being 3D polygon means it is a pad)
    Note that to get better 3D view you should have equal number of points from both sides of the 3D polygon representing the river.
  11. Hi propstuff,
    actually 'Create Site Model...' menu command does remember your settings. When you use the menu command after hitting 'OK' on the dialog, it stores the settings into 'SavedSettingsUser.xml' file. So, when you run again VW, and when you select the menu command, it will populate the dialog with those saved settings. (this includes the graphic settings)
    Note that this have meaning only for the menu command.
    Vlado
  12. Well, it's working ok. You need just to wait for it.
    The problem is that you have a stair object.
    This tool works with converting all objects in the cut layer into 3D polygons. And fits the walls to those 3D polygons. The problem is that those 3D polygons may intersect each other, and those itersections are to be found.
    When you have plug-in object that contains lots of 3D polygons within (like stair object) So it takes time to go trough all the polygons to check them for intersections.
    Well, this is a known issue, that we are up to find solution, so the performance would be improved.
    For now, you could either remove that stair from that layer, fit the walls, and move it back .... or just wait for the tool to finish [smile]
    [ 03-02-2006, 05:07 AM: Message edited by: Vladislav Stanev ]
  13. Hi Bradley,
    I just tried and I cannot see any problems with the purlin creation on Mac. They get created just fine.
    So, it probably is some kind of bug that you are experiencing, can you send me test mcd file that I can reproduce the problem?
    Send it to: vstanev@nemetschek.net
    Thanks
    Vlado
