In Vectorworks 2023, it was not possible to use the Updater; now, in 2024, I only encountered a minor error, as it searches for curl.exe directly in the Program Files. The option that existed up to version 2019 with "update-updater" was also much more practical to keep inside a BAT file in the Schedule. For 2024, I am using this code:
@echo off
SET updateFolder=C:\Batch\Vectorworks\Update
SET vectorworksPath=C:\Program Files\Vectorworks 2024\Vectorworks 2024 Updater
SET CLIBAT=%vectorworksPath%\resources\cli.bat
SET CURLEXE=%vectorworksPath%\resources\curl.exe
REM Check if the update folder exists
IF NOT EXIST "%updateFolder%" (
MKDIR "%updateFolder%"
REM Run the program to download the latest updater
CALL "%exePath%" download-latest-updater "%updateFolder%" -p w
REM Find the downloaded .exe file and execute it
FOR %%I IN ("%updateFolder%\*.exe") DO (
"%%I" /S -INSTDIR "%vectorworksPath%"
REM Copy curl.exe to the specified location without prompting
COPY /Y "%CURLEXE%" "C:\Program Files\curl.exe"
REM Run the cli.bat with the "update" option
CALL "%CLIBAT%" update
