Hokeewho
    6
Everything posted by Hokeewho
  1. Hokeewho
    Road Modifier
    I think you should try and see if you have at your road, in your settings, interpolation. You should try to fix there if you have some king od modifier then it could be cause of this.
  2. You should be able to change your print options here. Youu need to work with your layouts when you are in layout option tool seets. I hope this could help you. So you cant export from model, you need to go to layout structure and click somewhere.
  3. I keep seein this problem in last 2 days, i started to using this stories-floor option. In my German version i dont have any problem with this, but here i still cant find a solution, i tryed everything, Can someone help#? Top bound and Bot bound are just not working even if i have make all this to work.
  4. That is ok, but its not like when u are using paving tool. For example you can just adjust what kind of midifier u need and its done. I am saying, when i have 3d object or ifc one how to cut it in site simple
  5. Hallo i have a question how can i make a cut in Site plan with object without using other tools like example wall or Base for something, without using modifiers in tools palletes to cut the sites. Hope you understand what i think.
  6. Hokeewho
    Stairs
    Hello everyone, what is the best way to draw stairs in 3D-BIM in terrain and to se actual cuting. I have not manage to do this and tryed with different tools and variants. How are you guys doing this? Thanks
