JamesRS
    3
Reputation
0 Neutral
Personal Information
  • Location
    Canada
  1. Hi there, I have a worksheet on the cover sheet (sheet layer) of my drawing set that automatically updates based on the titleblock data of all other sheets within that same file to generate a drawing list. This works great for me. However, my project is now split over two files, one for my suite of plans and the other for my construction details. This is to enable me to have my plans use meters as units and my details use millimetres. Can the titleblock data from my construction details file be pulled into the worksheet in my plans file to create a full drawing list? If this has been discussed before please point me in the direction of previous discussion. And as always, all help is very much appreciated. James
  2. Thank you so much for your responses, it works well with the Site-DTM-Modifier class. Once I have done this can I control the grade at which my site modifiers "connect" to the existing topography of the site model. I.e. could you specify a downward grade of 1:4 (rise:run) for the surface in your screenshot to run down and meet the site model? I can see you can do that with some site modifiers like a pad but cannot quite work it out for my nurbs surface modifiers. Many thanks.
  3. Hi there, New to this forum so apologies if this has been discussed previously. We have recently moved to VW and I am loving it! However I cannot seem to figure out if I can use a NURBs surface as a site modifier? If not, is there a workaround and if so, how do I do this!! We are trying to place some organic shapes into an existing site for pump track design. Cheers, James
