Because I'm not entirely clear on the terminology regarding this question, I'm unable to find anything by googling it. My question is this: how does one continue an action after interrupting it with a rotate/move action. For example, if I want to draw a 3D polygon around a cube, I need to place a vertex on each side of the cube. In order to do this, I will need to use the Flyover tool and Move tool to give myself direct access to each side of the cube. However, if I begin the 3D polygon, place a vertex, then select the Flyover tool, the 3D polygon tool is no longer "activated". The line/vertex disappears and I have to begin anew. In SketchUp, I would select the 3D poly tool, then the flyover tool, then back to the 3D poly tool. The polygon continues if the next action directly after the Flyover is the 3D poly tool. It remembers what I'm doing. Does Vectorworks have this function?
