WrightDE
    4
Everything posted by WrightDE
  1. Hello! I've been doing a project where I found that doing the double line tool instead of a "3 point rotated mode" rectangle is way faster. However, I find myself missing the rectangles handles over the double line polygon handles. With the rectangle, you can select and move edges of the rectangle, but with the double line polygon, the handles only let you distort ans scale the shape, something I never really find any use for. Having the double line handles be the same as the rectangle handles would give them a lot more utility.
  2. Gotcha, so it's just the tool itself is janky. Understood. Thank you!
  3. I should note that this individual surface does not have a compound curve.
  4. Hello, I am making an archway with a compound curve and want to flatten out the surface to prepare for CnC. At it's widest point, the very top, the arch is 1' 5.8" thick. I convert the model into a NURBS curve. I select the inner surface and when unfolded, the widest part is now 1' 6.01" thick. The bottoms of the arch remain correct, but it seems that it gains .02" from the start to the middle of the surface. Is there a trick to unfolding that I'm not aware of? I've attached a file that has the model and the unfolded surface. wrong arch.vwx
