JerRenders
    6
Everything posted by JerRenders
  1. Hello, Also having this issue. I tried your suggestion Pat and it didn't help. Any other suggestions you can think of? My extruded circle is looking more like a dodecagon. Thank you,
  2. The wall behaves as it should when I paste into a blank document. There must be something in the file that I am missing.
  3. I have even tried modeling in a blank document where I am able to make the wall adjustments without issue but the wall defaults back to the original shape when I paste it into the working file. The top of the wall stays flat no matter what I do.
  4. Hey Jeff, That is exactly what I am trying to do except when I click and move the vertex, nothing happens to the wall. I have double checked components and both are set to be relative to wall and to follow wall peaks. I am early into the model so it's a 12' unstyled wall for now.
  5. Hello, I am having issues with the new edit wall tool and cant seem to figure it out. I am attempting to create a sloped, curved retaining wall but am having no success. When adding and adjusting the peaks I can see the red highlighted line in the wall but the wall its self doesn't change shape. I'm sure I am missing something extremely easy and obvious but I cant figure it out. I have tried adding and removing and moving points all around without the wall changing shape. Any suggestions?
  6. I am trying to make a sloped, curved wall and am having no luck with this new edit wall tool. Adding peaks and adjusting vertices isn't making changes to the wall. I can see the lines highlighted in red but the wall doesn't change shape. Is there a setting I am missing?
