Vasilia
    8
Everything posted by Vasilia
  1. Thank you so much. I had the fills/hatches (on separate design layers) on a 3D view instead of layer. I have used so many of your directions for correcting mistakes. Always so helpful. Now why can't I turn off the pdf's that I exported with the DWG in model space when in AutoCAD? I made them all on layer as well.
  2. Hi, My first few exports the fills were all fine. I was fine tuning my export to have what I wanted and experimenting since it is my first time. Now all my exports have a specific set of fills that show up in the wrong place on every export. Help please. Now that I know what I want the export to be format wise I can't get everything to export in the right location. See first export and the new exports issue. What have I done? I deleted the design layer and made a new one with the fill but it is still the same. Thank you
  3. As I enter the murky waters of exporting my file DXF/DWG with 6 sheets for AutoCAD a few issues arise. After many explorations and reading the forum, I still can't get it right. First, there are a few hatches that appear in random locations when opened in CAD. They didn't in the first export but now they are showing up wrong consistently even though they are fine in Vectorworks. Second, is there any way to export the layers (which I know export as classes) and all my sheets so that I end up with only one layer for each object in CAD Model similar to each layer I had in Vectorworks? I keep getting seeing multiple layers for the same objects in Model which reflects the objects each time they appear in a paperspace tab. I also cannot turn the layers off. Thank you, Vasilia
  4. Graphic Legend is great, thanks for suggesting. Using it but not sure how to get my plant image to appear instead of the 2D computer image. Maybe I have the image in the wrong place? This is going to be a powerful tool once I get it under my belt.
  5. Thanks for that speedy reply. I learned about the images on data tags here. Is this no longer an available function?
  6. VW 2023 - I have attached a plant image to a plant that I uploaded by going into Edit Plant Style- Plant Catalogue - Edit Image. I see these images exist now in the Select Plant Data screen. I have done the tutorials on how to attach an image in a tag and they are not working. When tagging in Annotation Sheet Layer just regular tagging occurs. I have also attempted to do this on the Design Layer with a tag and still I cannot get the plant image to appear. What am I missing. Is it some kind of preliminary setting? I am just beginning to explore what I can do with the tags and plant info for plants I create. Maybe I am putting it in the wrong way. Thank you for any help.
  7. Hello, Landmark Tool palette problem. All planting and wall drawing palettes gone. I started this journey when I couldn't access the shadow on a tree, I saved, rebooted as recommended on a forum and then upon reopening it said could not access a type of file so it was opening basic Vectorworks. I see now that this includes nothing I need. What do I do? About to go back to CorelDraw - two hours in and and I could have had this design completed already.
  8. Attempting to add other Existing Tree symbols to use in my file to more specifically reflect the type of trees on site. I can drag and drop 2D plant symbols from the Vectorworks Library into the ET symbols folder of my .vwx file. They appear in the folder but I cannot view them when I select an existing tree 2D Properties under the Object Info tab. All the info I read online says to export the selection but export is not an option. I have been using Vectorworks Landmark for 3 weeks now. I must be missing something obvious. Ideally I want to add the species specific symbol but thought that might be problematic. If is it possible to use species specific images in the existing tree tool I would love to know how.
