Ema Gia
    43
Everything posted by Ema Gia
  1. This is how it looks. The letters are a little blurry, but when I double click and change settings (dpi, font) it does not work and remains unchanged.
  2. Hi, I am working on a landscape plan. I have to include Excel spreadsheet and then export the whole project as an image (as I need to present my assignment as a Word document) The text within the spreadsheet is a little blurry even though I set dpi 500. Anything else I can try? I double clicked on the spreadsheet once imported in VW and tried to change font but it does not work ,font remains unchanged. Any setting I tried to change with double click on the spreadsheet (see pic attached) does not work. Many Thanks!
  3. Hi, beginner question: how can I chamfer those angles? Thanks for your help
  4. Hi, I created this legend. How can I insert H (for height) and S (for spread) before the numeric values? thanks!
  5. Thanks Tom! I am new to Legend tool, would you please explain me where to find the graphic legend you've attached above please? And how can I add the other paramenters?
  6. Hello, would anyone be able to guide me on how to add Common name, botanical name and mature height and spread in the legend please? thank you!
  7. Beginner question: I need to add Plant name and Mature height and spread. How can I add this data next to the object? thanks!!
  8. super helpful Jeff!thanks a lot!
  9. Thank you Hi Jeff, thank you very much for your reply. Would you please guide me through the 'from the viewport enter the design layer'? thanks again!
  10. Hello , I'd like to work on my project and see how it will appear on a A3 page (size I chose for the viewport) without switching every time to viewport. Basically I'd like to set the same page for design layers screen and viewport. I tried to set the same page (please see pics attached) but it still looks different. Thanks for your help!
  11. Hello, I have to present my 2D landscape design in microsoft word document. When I create a viewport, I select A4 or A3 paper size. Then, I click export, Image file, All visible object and I obtain an Image which is smaller than the paper size that I set. How can I obtain actual A4 or A3 size images? Thank you
  12. Hey, I still need help with this if somebody's available please! thank you
  13. Hello, I am manually creating a plant legend (Excel table) and I need to basically copy and paste plants in order to create a legend. In the plan every plant has a different size.. Can I edit the dimension only in the legend but not in the plan? Thanks
  14. Thanks Amanda! I managed to create a sheetlayer and put 2 viewports on it, it works! only 1 more question.. how can I set viewport stacking order?
  15. Hello, I've been trying to create a sheetlayer in b&w, except for one layer that has to be in colors. I am not able to make this function work.. eithrer Layer colors is ticked or unticked, it does not make any difference. I tried with Advanced option, b&w only and then ticked the Layer colour button for the layer I need in color, but nothing happens. I also tried to tick and untick layer override and layer visibilities, but nothing changed. Any idea what I can try? Thanks a lot!
  16. Thanks for your help Mark. I followed your advice but it partially worked. The picture and the symbols on the plan are on the same layer but only the picture is in colour, I am not able to get the symbols in colour, tried a few times but nothing changed. Do you know if there is another way to make it work? is there any other setting to change? thank you very much!
  17. Hello everyone, I need to present a viewport in black and white, except for one layer that needs to be in colours. How can I do this? Thanks!
  18. Hello, how can I distribute the yellow dots along the arc? tried to use Surface array but found it quite complicated.. Thanks for your help!
  19. Hi Pat, thank you for your quick reply! Defaul resolution is 900 pixel/in.. should I change it?
  20. Hello, I created a concept plan in vectorworks. Now I need to import the created document in Photoshop and develop a moodboard. I cannot saved the plan as PDF because Photoshop asks me a password to import PDF document that I don't have. Any suggestion? Thank you!
  21. thank you very much all!!
