acrow
    3
Everything posted by acrow
  1. Starting with the top image I try using the snip tool along the line in the second image. Object turns red, but nothing happens. I also tried using the project snip tool using a line that crosses all the way over the object with the same results. I attached a screenshot of the entire object for context. Currently using VW 2023 SP5
  2. I tried doing this, but when I use section solids it deletes the other half of the object. Is there a way to make section solids retain both sides of the split?
  3. What I'm trying to do is split a rectangular prism into 2 sections whose lengths add up to that of the original object. Using the Project Split on a line across the top face of the prism does this, but I am left with a group of individual faces, not two solid objects. I tried using the section solids command in the model menu using a 2d rectangle intersecting the prism, and this works better because it leaves the prism intact instead of separating it into individual faces, but this deletes the other half of the object I'm trying to split. Is there a way to split a 3d solid into two sections without deleting half of it or ending up with a group of faces?
