harrybilney
    6
Everything posted by harrybilney
  1. It doesn't have to be a symbol. Basically it needs to be something I can use in different files. Basically I have 10 pop ups with various colours in a record format, and then 10 identical squares in the symbol. I'm trying to change the colour of each square based on the record format.
  2. Trying to change the background colour of an object within a symbol based on the value of some text in the same symbol. Is this possible. The only way I can currently think of is with Vectorscript but not sure where to start.
  3. @Jonathan Pickup@Pat Stanford Please see attached file. Simple square that is a symbol. Record is attached but when looking at the 'Modify by record' window, only one option is showing. Color Record Test.vwx
  4. I believe so yes, it is just a simple rectangle. I've attached the record to the rectangle within the 2D component, but I still get the same problem. Just as a test I tried this in a blank file too and still the same issue.
  5. I'm trying to set the colour of an object via a record value. I have a pop up with a few predefined colours in, and want to assign them within the 'Modify by Record Value' function but when I choose 'Colour Value' I only see the first option in the pop up in the values list, not all 12. Is there any reason behind this? What am I doing wrong?
