LongpreArch
    4
Everything posted by LongpreArch
  1. Thanks, Pat, I tried deleting all slabs from the project, and the problem remained, but when I deleted the closet doors on the second level... as my Vectorworks models often glitch out with doors on a regular basis. The project fixed itself. However, it's only when the closet door is added to the interior walls that the whole model breaks... so confusing.
  2. Thank you for pointing that out! I didn't realize the distance from the origin was so significant – it was indeed a foolish oversight on my part. I've now adjusted the position and aligned it with the origin point as suggested. Unfortunately, the issue still seems to persist. Any further insights would be greatly appreciated! At least the slabs show up now
  3. Hey Guys, I am having a severe issue with a particular project that I am working on that is going to have to lead me to redo a clean file from scratch, but I thought I would ask for help anyway. This model breaks when you add a slab to it. I have tried everything to isolate the issue but I cannot figure it out. Here is an image of it before adding a slab: And After: Nothing fixes it unless you delete the slab, but even then sometimes it just stays broken. When you copy it into a blank file it corrects itself. You also cannot see the Slab in 3D view, only in 2D. Then the whole file breaks down and many errors start occurring. Please let me know if you can fix this or if the problem is replicated on your computer. MESSED UP HOUSE.vwx MESSED UP HOUSE.vwx
  4. Unfortunately, after reading this thread, I was hoping for some good news, but this bug happens to me ALL the time. It occurs in every project I work on, regardless of the computer or version of Vectorworks I use, and has been doing so since 2022. This issue reoccurs over and over and no one from tech support has been able to help. The only solutions I have found that seem to fix this problem involve deleting all the wall peaks under AEC, or trying to manipulate the wall in some way. This could mean moving the wall, connecting another wall to it, or copying the wall into another blank file and then back again. I sometimes also try saving the file as an older version and then reopening it in the latest software. The updating process seems to rectify the issues. These methods have proven helpful, but this bug is extremely irritating and consumes a lot of my time trying to rectify it. Consequently, I often end up on these forums, searching for answers. I would really appreciate it if this issue could be fixed.
