I'm in a pickle. I have a suspicion that there is a simple step or option that I am overlooking or have set improperly. The issue is that when I place doors in a wall, the jamb doesn't insert relative to the center of jamb within the wall. It has an offset, so the edge of the jamb sits flush with the structure, and the GWB is proud of all of it. Obviously not how you want your doors to behave.
I've attached the file and some settings screenshots. I've also searched the forum and a few stabs at google searches with no luck.
Any help would be greatly appreciated.
EDIT: Additional info that may help - I've adjusted the General - Insert Relative To setting and the Jamb - Use Wall Depth setting. I've experimented with exterior doors in exterior walls, interior doors with interior walls, and generic doors in both interior and exterior walls. I was following along with a lesson and used the styled doors that the instructor used as well as the same settings they used, and after not getting the expected result, that is when I started to experiment.
Concept Walls v2023 training 07242023.vwx
