Eva99
    5
Reputation
0 Neutral
Personal Information
  • Location
    Iceland
  1. Hi, im having trouble with lights in VW, i am using macOS13.0 and VW 2022 version. So when im setting up my lights i can see a light from it in my space( on the ground and on objects) but when im exporting there is no visible light bulb showing from the light source. On the photo i have made a circle around the light where the "light" is coming from. What can i do to fix this?
  2. Hi, i have tried polylines and extrude but i dont get it to work, im trying to move it in 3D space to be on the wall vertical
  3. Hi, im having trouble with the text that I want to have on my architecture document. Im trying to write some text and putting it on a wall vertically in 3D, I am able to get the text to 3D but when I try to move the text or modify - rotate - rotate vertical, the text goes at some angle and is not vertical and Im unable to put it on the wall, can someone give me advice? Best regards
  4. By editing in 2D by using blue dots to shrink it down. But it doesn't change in 3D.
  5. Hey, I'm having trouble editing the dimensions from e.g. table. This table is in recourse manager, inside Vectorworks library and is called "Furn Office Knoll Conf Table Boat 216in" When I am in 2D mode(top/plan) I am able to modify the size of the table so it fits the floor plan by selecting the table and shrinking it. But when I go to the 3D view (right isometric) the table is still in the original size and is way too big. Under object info there is no possibility to adjust the size.
